Online Now [223]:
Visitors: 223
Today: 32190
Total: 116574574
Forums › The Car › 206 Problems › clutch judder/stiff pedal?
paulspug
PostPosted: Wed Mar 14, 2012 10:36 am Up
hi ppl,
bought my 206 gti (2002) just over a week ago;but i didnt relise -too hell bent on owning one- that the clutch is pretty stiff when you press the pedal, that and it judders in 1st all the time .Again i was immune from noticing as i thought being a different car it was my fault adjusting to the driving position.
reading your forum it looks like a new clutch is needed, but will it make the pedal lighter to foot after a new clutch has been done, or is there a bigger picture? i.e. flywheel / slave cylinder will want looking at.
thanks Smile
Big_Rich180
PostPosted: Wed Mar 14, 2012 10:44 am Up
I had a non OEM clutch fitted in my 180 and that was a lot lighter than the OEM, personally i prefer the heavier clutch though.
marrygold75
PostPosted: Wed Mar 14, 2012 4:07 pm Up
just put a new clutch in mine and the pedal is as light as a feather.
have a nice day
paulspug
PostPosted: Wed Mar 14, 2012 6:34 pm Up
ok thanks all
i'll get onto seeking a LUK clutch kit Very Happy
james180
PostPosted: Thu Mar 15, 2012 7:42 am Up
My 180 used to judder really bad when pulling away from a stand still.
I filled my rear engine mount with silicone and now its 100 times better.
Its still there but i hardly notice it any more just a very slight rumble.
Still going to fit a new clutch when i get time but its so nice now compared to how it was.
Understeer is a crime.
paulspug
PostPosted: Fri Mar 16, 2012 1:43 am Up
nice, didnt think of that aswell, nothing to lose ty
Sprotty
PostPosted: Sun Mar 18, 2012 6:45 am Up
How did you stop the silicon running out before it set? Thinking of trying this before going down clutch and flywheel change!
Life at full throttle...
james180
PostPosted: Sun Mar 18, 2012 6:57 am Up
I just squirted loads in and left it for a few days to go off.I dont drive it during the week so its not a problem.If you need your car during the week you could fill it on a Friday afternoon and leave it till Monday,should be set by then.
The judder is still there but the difference is very noticeable.
Sprotty
PostPosted: Sun Mar 18, 2012 7:20 am Up
Will give it a try, got cambelt to do next month so need to put off clutch for a while.
Zoe86
PostPosted: Mon Mar 19, 2012 11:08 am Up
I would recommend a new clutch if it is juddering and I am not sure they are too expensive either.
Watch out... you have a hot hatch on your ass!
Sprotty
PostPosted: Mon Mar 19, 2012 1:53 pm Up
Gonna be doing it just need to make time, got a flywheel to be skimmed too.
Zoe86
PostPosted: Tue Mar 20, 2012 10:17 am Up
From what I have heard it is not the easiest car to work on. I hope that solves the problem though, good luck
Sprotty
PostPosted: Tue Mar 20, 2012 2:18 pm Up
Managed a gearbox change on a celica gt4 in a day so should be okay I hope!
james180
PostPosted: Tue Mar 20, 2012 3:33 pm Up
Good work.I had a faff for 4 years so i know what a pig they are to work on.
bisphenol-a
PostPosted: Mon Mar 26, 2012 10:17 am Up
my clutch of my 180 is bloody stiff. had mild judder on 1st but I work around that problem by giving the engine more gas for a split second longer before clutching into 2nd.
thought I needed a new clutch so I asked the master mechanic on my last service. tells me my clutch is fine and there is no need to change. anyhow the stiffness irritates me, I'm wondering if spending money for a new clutch by Peugeot would solve the stiffness. would it?
ohh! there was this time where my clutch sounded like there was metal bits crunching or breaking off when moving off from stationary. happened only a few times on 1 particular day but has been silent ever since.
do I need a new clutch? stiffness and some crunching noise?
