Posted: Mon Mar 12, 2012 5:52 pm |
My local garage want to charge me £240 total to supply and fit a new pump
Posted: Mon Mar 12, 2012 5:58 pm |
MattyP wrote: |
My local garage want to charge me £240 total to supply and fit a new pump  |
Ouch its half hour to an hour job mate and very easy to do
Posted: Mon Mar 12, 2012 6:14 pm |
How much, they buying the tools to do the job aswell are they?
Pump £40, new fluid £7. 20-30 min job. Easy job aswell. Get a mate to help, always easier with 2 especially removing the aux belt.
Posted: Mon Mar 12, 2012 6:25 pm |
I have a pump that you could have for cheap enough as I need the space.
As long as you don't have variable power steering
Posted: Tue Apr 21, 2015 8:44 am |
Hi , just come across this thread as I am getting the same fault. Did you change the pump and did this solve the problem ??
Posted: Tue Apr 21, 2015 4:42 pm |
thats a massive bump of an old thread
Posted: Tue Apr 21, 2015 7:50 pm |
If you get a screaming noise from the power steering it may be the pump or it may be an o-ring that has failed. I had the loud screaming noise on my X-reg 206 and it was the o-ring that had begun leaking. 20p for the ring.
The leak is not bad so topping up with steering fluid will do the trick for £4. It'll get worse over time so get it fixed but a pump can be bought for £20 online. Check your lines and your fluid first.
Shop around, Google will save you a fotune
| I ain't nuts, I'm condiments, I've been promoted | |
Posted: Thu Apr 23, 2015 4:22 am |
Ive had a look under the car and can see there's a split in the power steering pipe, so the fluid is leaking. Booked in to garage to be fixed now.
