Latest: Puggingalong
Overall: 17129
Online Now [368]:
Visitors: 367
Today: 14869
Total: 101526933
Forums › The Car › 206 Talk › 206 gti arches
206 gti arches
Kelz
PostPosted: Wed Mar 14, 2012 5:57 pm Up
How are the 4 arches normally fitted on a 206 gti?
Mine has like an outline as if they had been there before but do not currently have them
Kelz!
-Dave-
PostPosted: Wed Mar 14, 2012 6:41 pm Up
Trade Rating: +36
They are held on by clips. A thin rubber should go along them against the body also.
Ex 206 Owner.
Kelz
PostPosted: Thu Mar 15, 2012 2:49 am Up
Where do the clips go?
Kelz!
craigdmjv
PostPosted: Thu Mar 15, 2012 3:15 am Up
under the arches over the lip of the arch and body
Kelz
PostPosted: Fri Mar 16, 2012 10:53 am Up
Can't have had them on then as there are no holes for any clips on the arch of the car or bodywork
Kelz!
PostPosted: Fri Mar 16, 2012 11:28 am Up
Just like paperclips they don't need holes to do the job.
