Online Now [315]:
Visitors: 314
Today: 2242
Total: 105265696
Forums › The Car › 206 Talk › 206 1999 1.4 auto my daughters car
charley
PostPosted: Thu Mar 15, 2012 9:25 am Up
hey guys and gals.
got one here for you , 206 started missing as i thought.
usual checks plugs , put new ones in. coil rail tested fine.
injectors tested fine. compression test 1,2,3,, 210psi 4 140psi
looks like i need to replace rings.
what i need to know is how long to strip down . and cost etc.
or i am thinking replacing the engine , might be an option .
when engines get replaced do they then need to go to the garrage to be re jiged to match the ecu module. regards guys
just a crazy old man trying to fix his daughters\r\ncar --
Bummers
PostPosted: Thu Mar 15, 2012 12:39 pm Up
did you do the compression test more than once? Wet & dry as well?
Low compression in one cylinder from a single dry test doesn't necessarily mean piston rings.
2003 206xsi 1.6 16valve
craigdmjv
PostPosted: Thu Mar 15, 2012 1:22 pm Up
maybe split hose ??
charley
PostPosted: Thu Mar 15, 2012 4:26 pm Up
yes did dry first 3 times on all cylinders 10 rotations
then poured little amount of oil into cylinder and tested again
compression was 270 then dry it was 140psi.
Bummers
PostPosted: Thu Mar 15, 2012 5:12 pm Up
What was the wet compression result on cylinder 4?
PostPosted: Thu Mar 15, 2012 5:14 pm Up
Rings on a TU, they never fail.
Chuck another TU3 lump in it if you are sure yours is that knackered.
Bummers
PostPosted: Thu Mar 15, 2012 5:28 pm Up
Could just be a valve, be worth taking the head off to check before throwing another lump in there.
