Posted: Thu Mar 15, 2012 3:51 pm |
Hi
1.9d - non turbo -
Starts and ticks over fine - pulls under hard throttle ok.
But!
2000 ish revs - light throttle - perios of loss of power accompanied with a "pinking" noise. ( goes on acceleration or deceleration)
and
tendancy to die on pull away under load and needs hefty acceleration
Does this ring any bells?? I'm struggling! - Thanks!
Cheers
| | ![](images/spacer.gif) |
Posted: Fri Mar 16, 2012 1:43 am |
try unplug egr value see if that helps at all. then you now that it blocked or if don't help then it sumthing else
Posted: Mon Mar 19, 2012 7:55 am |
Brilliant - spot on!
Unplugged today and car now running properly.
Will replace valve
Many thanks for the reply - I owe you a pint!
Cheers
Posted: Mon Mar 19, 2012 7:58 am |
dinsdale0042 wrote: |
:D
Will replace valve
Cheers |
You dont need to replace it simply pull it off and clean all the soot out of it.
Posted: Wed Apr 18, 2012 12:17 pm |
Don't bother cleaning it, being a non-turbo it serves no purpose (other than NOx reduction), it simply fills the engine with crud. Un clip the pipe running from the exhaust to the valve mounted on the inlet manifold and glue a 2p or something similar over the valve. It doesn't matter which glue you use as it's simply to hold it there when you fitting the pipe back on, which clamps it any way. For good measure you can shove some rockwool (not fibreglass) insulation down the pipe (the one going to the exhaust) to clog it.
Next step enjoy a better running, cleaner engine ![Smile Smile](images/smiles/icon_smile.gif)
Posted: Wed Apr 18, 2012 3:21 pm |
Knocked the electric connector off and engine runs ok
Will have a look at the pipe at the weekend
Many Thanks ![Smile Smile](images/smiles/icon_smile.gif)
