Latest: Beduff1977
Overall: 17134
Online Now [401]:
Visitors: 400
Today: 115045
Total: 109285672
Forums › The Car › 206 Problems › Fuel Pump Relay Location (53 2.0L HDI)
Go to page Previous  1, 2
PostPosted: Sun Mar 18, 2012 8:19 am Up
You need a decent diag tool that will allow you to run a actuator test.
Have you tested the pump itself?
PostPosted: Sun Mar 18, 2012 10:58 am Up
What was the condition of the fuse and terminals like? The fuse might be ok, but mine was causing the connections to burn.
tris_asd
PostPosted: Sun Mar 18, 2012 2:27 pm Up
I got it started for about 20 seconds. But then it died. I was fiddling rou d with the fuses and that general area, and then I put it back together and turned the key, and the fuel pump came on and the car fired up. Then it died like 20 seconds later.
Does this indicate a loose wire somewhere? Hmm
cc
PostPosted: Sun Mar 18, 2012 2:34 pm Up
If it fired up, but died, i'd check the fuel pump. Once going it shouldnt cut out until you turn the ignition off.
PostPosted: Thu Apr 05, 2012 12:45 pm Up
Any update on this?
sayclosed
PostPosted: Wed Jul 04, 2012 3:26 pm Up
Did you find the relay? I had a "mechanic" for 2 hours checking on my car looking for this and no luck.
jmmc
Page 2 of 2
