Online Now [575]:
Visitors: 574
Today: 106565
Total: 145068992
Forums › The Car › 206 Problems › power steering problem??
TCW206
PostPosted: Tue Mar 27, 2012 2:50 pm Up
so today the motor started wineing every time i turned the wheel soo im thinkin needs more fliud?? does anyone know wot sort i need?? its a 1lt 2002
Thanks alot Smile
1.1 more door
gaffa786
PostPosted: Tue Mar 27, 2012 3:06 pm Up
any power steering fluid will do the job
TCW206
PostPosted: Tue Mar 27, 2012 3:14 pm Up
cheers buddy !
1.1 more door
gaffa786
PostPosted: Tue Mar 27, 2012 3:16 pm Up
wait u might want to let some of the experts answer you question before u take my advice lol
there's loads of em here deyl answer it and me if im wrong
Mrs_Howey
PostPosted: Tue Mar 27, 2012 3:27 pm Up
If you check in the manual for the car it will tell you the correct power steering fluid as there different grades just like with engine oil, i don't advise just sticking in what you fancy, might not do it any good. Have you checked the fluid as well? you can check it's level on the stick attached to the lid. It might be the power steering pump on it's way out.
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
PostPosted: Wed Mar 28, 2012 3:27 am Up
Thoroughly check for leaks then top-up with ATF.
gaffa786
PostPosted: Wed Mar 28, 2012 5:35 am Up
How would u chek for leaks? Just park in 1 place for ages them move of and chek where you wer parkd?
Or is it that just a dumb idea
