Online Now [263]:
Visitors: 262
Today: 97556
Total: 142809799
Forums › The Car › 206 Talk › 206 idle control valve?
Adam2061994
PostPosted: Tue Apr 10, 2012 5:02 pm Up
would a bad or blocked idle control valve cause a loss of power at low revs? just wondering?:D
206 1.6 owner
Jammie_1989
PostPosted: Tue Apr 10, 2012 5:23 pm Up
Going to give mine a clean and the VVT Solenoid hopefully do the trick.
206 gti 180
Adam2061994
PostPosted: Tue Apr 10, 2012 5:36 pm Up
is that whats yours is doing pal? like hesitate, im gonna get a new valve for it and clean throttle body out i think! Smile
206 1.6 owner
Jammie_1989
PostPosted: Tue Apr 10, 2012 5:54 pm Up
Yeah seems underpowered under 2k revs. Instead of buying things willy nilly get yourself some carb cleaner remove the VVT solenoid and the idle control value and give them a blast. Cans are about £4 delivered off ebay probably similar in halfords.
206 gti 180
Adam2061994
PostPosted: Wed Apr 11, 2012 4:18 am Up
okay matey thanks for that!:)
206 1.6 owner
Big_Rich180
PostPosted: Wed Apr 11, 2012 4:51 am Up
1.6....VVT solenoid?
I didnt think the 1.6's had VVT.
Bad plugs or coil pack could cause it but so could alot of other things, take it to a garage and get the codes read.
PostPosted: Wed Apr 11, 2012 5:11 am Up
Correct, it hasnt Laughing
Only the GTI 180 & the 1.4 16 valve in the 206 have VVT fitted.
Adam2061994
PostPosted: Wed Apr 11, 2012 5:56 am Up
so should i just replace the valve? and see if this is the problem, as ive had new spark plugs and coilpack to attempt to resolve it but nothing...
206 1.6 owner
Big_Rich180
PostPosted: Wed Apr 11, 2012 6:14 am Up
Personally I dont see how the ICV could make you lose power at the low end.
Could it not be crappy fuel or dodgy injector or cam timing?
What about your exhaust is there any blowing from it?
Have you cleaned your air filter out?
Adam2061994
PostPosted: Wed Apr 11, 2012 6:31 am Up
its running rich atm, i had it on diagnostics it came up with water coolant sensor, MAP sensor which i had them replaced, my coilpack and plugs were replaced, but it also came up with throttle actuator, but my throttle is cable so i dont understand? but when its idling or put into neutral it does continuously drop and go below 500rpm and stall most times? some mornings its fine then some days are bad and it stalls? its driving me mad! so gonna have the idle control valve replaced, and would the throttle actuator explain my loss of power under slight throttle? i have a 2000 reg 1.6 8v xs?
206 1.6 owner
Danny.
PostPosted: Wed Apr 11, 2012 7:05 am Up
Jammie has a 180...
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
Big_Rich180
PostPosted: Wed Apr 11, 2012 7:09 am Up
Jammie has a 180...
The OP has a 1.6 therfore making the VVT comment pointless.
PostPosted: Wed Apr 11, 2012 10:08 am Up
I have the same problem on my gti 137, have replaced the icv but it's still having the same issues where the revs drop right down when car is stationary and then cuts out, took the car to my local garage and they checked it on their diagnostics machine and it read 0 error codes so going to take it apart and clean it and see how that goes
PostPosted: Wed Apr 11, 2012 12:00 pm Up
-sighs-
Just because no error code has been flagged doesnt mean the sensor is not dying, as it can still be within the ECU's tolerance but just not enough to flag a code. Garages will never learn this.
Matty PM me, as i may be able to assist
But back to the OP the throttle actuator i 'think' is also refered to as the throttle position sensor located below the ICV, get one from a scrappy and try
Adam2061994
PostPosted: Wed Apr 11, 2012 2:03 pm Up
Addaz wrote:
-sighs-
okay mate well what is the purpose of the throttle actuator? and im changing the idle control valve tomorrow as it sounds like this, thanks for all your help!:)
206 1.6 owner
