Latest: Beduff1977
Overall: 17134
Online Now [1425]:
Visitors: 1424
Today: 116672
Total: 107518327
Forums › The Car › Solved 206 Problems › Revs hang before dropping to idle [SOLVED]
PostPosted: Thu Apr 12, 2012 9:52 am Up
When idling I press the accelerator to 3500 rpm, and when I let-go
the revs hang-around 2K rpm briefly, then drop to 750 idle again.
Cable is not sticking and ICV should be OK and sealed properly.
I also don't notice it in normal driving though I assume it's happening.
SOLVED:
Various things tried, see posts.
PostPosted: Sat Apr 14, 2012 2:22 am Up
Sorted it.
Please move.
PostPosted: Sat May 19, 2012 7:20 am Up
Also, now moved the R-clip as the cable was a bit too tight preventing butterfly return when cold.
PostPosted: Mon May 06, 2013 4:35 am Up
Also, repeated intake/exhaust valve tapet adjustment (until the seats re-form and settle) massively helped the issue when it looked like it was about to start doing it again.
I believe this was likely the root of the problem, and all the other work was interacting.
