Latest: sparrowdclxvi
Overall: 17139
Online Now [119]:
Visitors: 118
Today: 17591
Total: 113507175
Forums › The Car › 206 Talk › quick question
quick question
coopskin
PostPosted: Sat Apr 14, 2012 6:46 am Up
Trade Rating: +13
Hi all,
can you replace your brake pads without needing to replace your disks?
as i've heard a few times you should replace both at the same time but is it neccessary?
thanks in advance Smile
PostPosted: Sat Apr 14, 2012 6:51 am Up
Yes you can.
Edit: It's if you replace your discs, you need to replace your pads due to the way they wear.
I do
coopskin
PostPosted: Sat Apr 14, 2012 6:55 am Up
Trade Rating: +13
cheers chaps!
PostPosted: Sat Apr 14, 2012 9:56 am Up
As long as the discs are not warped, cracked, lipped / rusted badly or below the minimum thickness ( which is normally marked on the disc somewhere ) then leave them.
The asbestos free pads used today are a lot harder wearing on the discs then the olden days Laughing
dj71
PostPosted: Sat Apr 14, 2012 10:00 am Up
replaced discs and pads on mine yesterday, cost £55
dj71
