Latest: Kifi69
Overall: 17183
Online Now [385]:
Visitors: 384
Today: 83842
Total: 144101694
Forums › The Car › 206 Problems › Horn no worky!!
Horn no worky!!
fatboyslim
PostPosted: Sat Apr 14, 2012 5:42 pm Up
Ok found out earlier my Pugs horn has stopped working
Was too dark to do anything with,so gonna have a look tomoz
Is there any known problems to look for?
Or just a general check connectors,fuses etc
Yes I own a CC and I'm neither gay or a hairdresser!!
L5_UKS
PostPosted: Sat Apr 14, 2012 5:59 pm Up
Maybe its not feeling horny?
On a serious note it will be the wire connectors corroded, common issue had it with mine.
Dabamash
PostPosted: Sat Apr 14, 2012 6:09 pm Up
Staff - Daba
It'll just be corroded. Happens a lot due to its position...not exactly water proof
PostPosted: Sun Apr 15, 2012 12:48 am Up
as the guys said Very Happy
PostPosted: Sun Apr 15, 2012 2:30 am Up
Mine stopped working, probably from water intake. When i replaced it i turned the horn the other way round.
ARRAN
PostPosted: Sun Apr 15, 2012 3:30 am Up
Check the easy option first, fuse. Then go from there.
See my project here.
PostPosted: Sun Apr 15, 2012 4:31 am Up
Normally the wires will be broken just behind the connector plug - must be a common 206 problem as Peugeot sell a loom repair kit for it Laughing
