Latest: lio94
Overall: 17181
Online Now [60]:
Visitors: 59
Today: 29709
Total: 141412356
Forums › The Car › 206 Problems › seat belt thing?
seat belt thing?
anton1989
PostPosted: Thu Apr 12, 2012 8:14 am Up
Trade Rating: +16
does anyone know what this part is called and how to both remove it and fit it the correct way? i broke mine while fitting the rear door card Confused
thanks in advance.
ment to be here
lmilligan
PostPosted: Thu Apr 12, 2012 8:30 am Up
It's the seat belt height adjuster, but I don't know how to fit it Laughing Looks as though it just clips in.
anton1989
PostPosted: Thu Apr 12, 2012 8:48 am Up
Trade Rating: +16
if only it was that easy.
anton1989
PostPosted: Thu Apr 12, 2012 8:51 am Up
Trade Rating: +16
can't find them on ebay Sad
lmilligan
PostPosted: Thu Apr 12, 2012 8:54 am Up
I doubt you'd see them on eBay, pm someone who's breaking cars on here of you need a new one.
anton1989
PostPosted: Thu Apr 12, 2012 8:56 am Up
Trade Rating: +16
good idea Very Happy they can tell me how to remove and fit it also
anton1989
PostPosted: Thu Apr 12, 2012 8:57 am Up
Trade Rating: +16
would it fail m o t without one do you think?
gaffa786
PostPosted: Thu Apr 12, 2012 9:06 am Up
Yeah im sure they just go inside and you just tighten the torx screw.
anton1989
PostPosted: Thu Apr 12, 2012 10:20 am Up
Trade Rating: +16
there is no torx screw?
Squeaker
PostPosted: Thu Apr 12, 2012 11:05 am Up
anton1989 wrote:
In this picture, the top part,i flicked off with a flat blade screw driver, then that hides a screw, if i remember right.
I took mine off the other day, can't remember what i did with them tho. Ill see if i can find them in a bit.
Squeaker
PostPosted: Thu Apr 12, 2012 11:28 am Up
Yeah, ive just checked mine,i think you've broken the height adjuster, heres some pictures of mine.
First pic is of it broken down
As you can see the metal pin in yours is no longer attached to the lifter.
this is how it goes back together, you can see where the screw goes below the pin.
Then with the cap back on, cap grabs the pin which moves the height up an down.
anton1989
PostPosted: Thu Apr 12, 2012 2:07 pm Up
Trade Rating: +16
how did you get it off? i tried pulling the thing on the right in your first picture off and the whole thing came off Confused
Squeaker
PostPosted: Thu Apr 12, 2012 2:20 pm Up
Like i say its looks like you've broken the adjustor, the top plastic part will move out a little as you pull on it, when you pull it, it pulls the locator out so you can move it up and down, pull it out and then pull a little harder, it just sits tight on the locator, it should just pull off.
When thats off you'll see the screw, once you undo the screw, the bit that falls off the back, is the bit thats broken off, as you can in my first picture the locator pin should still be connected to the slider.
Hopefully my pictures show how it all goes together.
anton1989
PostPosted: Thu Apr 12, 2012 3:15 pm Up
Trade Rating: +16
i can see what i have broke but the bit that should have just poped off in the 1st place still budge? it's just twisting, and i've broke the other one now also!
not coming off?
Squeaker
PostPosted: Thu Apr 12, 2012 3:24 pm Up
Why not just try to seperate the already broken bit?
