Latest: tbafonso
Overall: 17130
Online Now [265]:
Visitors: 264
Today: 14652
Total: 103945059
Forums › The Car › 206 Problems › Gti aircon question.
rick-gti
PostPosted: Thu Apr 19, 2012 10:31 am Up
Before I fit my 138 gti engine, I want to run it with no aircon. I plan to remove everything bar the pump. Will the climate control work ok if I do this? My gti at the moment has no gas so it doesnt work anyway. And its £70 to get it re-gassed by me.
clio 197sport owner
PostPosted: Thu Apr 19, 2012 10:37 am Up
I think if you have the pump there is should be ok, I know when the auxilary belt went on my GTi the climate control wouldnt work at all, the display didnt even come on.
PostPosted: Thu Apr 19, 2012 10:40 am Up
You want to remove it permanently? I've taken mine out, everything including condensor and pump. I use a shorter belt and everything still works.
rick-gti
PostPosted: Thu Apr 19, 2012 11:03 am Up
Yeah I want to take it all out, what size belt do you use with the pump removed?
clio 197sport owner
PostPosted: Thu Apr 19, 2012 11:52 am Up
Have a trawl through my project topic. It has a picture in there of the belt with the part number on it.
I took all the wiring out of mine too.
rick-gti
PostPosted: Thu Apr 19, 2012 12:02 pm Up
Ok i'll have a look. Should save some weight removing it all too.
clio 197sport owner
PostPosted: Thu Apr 19, 2012 12:16 pm Up
Pump, condensor, piping etc weigh 10kg.
PostPosted: Thu Apr 19, 2012 12:21 pm Up
Can you still use the heater/fan ok Edward?
PostPosted: Thu Apr 19, 2012 1:49 pm Up
Yes it works the same as before. Only difference is switching the A/C on makes it no cooler.
PostPosted: Thu Apr 19, 2012 1:55 pm Up
Does yours still default to a/c when you start the engine? I dont know why but with no belt mine wouldn't work at all.
