Latest: tbafonso
Overall: 17130
Online Now [382]:
Visitors: 381
Today: 45973
Total: 103712783
Forums › The Car › 206 Problems › 1.4 zest 2 alloy wheels
dixon293
PostPosted: Sun Apr 15, 2012 4:47 pm Up
new to this site and a bit of a newbie to modding cars and came across a set of nimrod alloys and put them on my car... only problem is that the front passenger side wheel sticks out the arch a fair bit more than the drivers side. anyone ever came across this or know what could be the problem.. can also get pictures to help explain
Matt
PostPosted: Sun Apr 15, 2012 4:54 pm Up
Trade Rating: +32
Have a look at the back of both wheels, check that the specs match.
Only thing I can think of is that you may have 1 from a 406 and 1 from a 206.
dixon293
PostPosted: Sun Apr 15, 2012 5:02 pm Up
they need refurbed badly anyway so will be sure to check them over. thanks for the quick reply.
dixon293
PostPosted: Mon Apr 16, 2012 11:11 am Up
picture to explain... measured wheels and they seem to be the same size... tracking is out but dont think that could cause that?...
PostPosted: Mon Apr 16, 2012 11:33 am Up
Bent hub, my GTi has this issue
And currently ive replaced everything apart from the kitchen sink and the hub
You may subframe but its a heavy thing to bend/move across, hubs can bend very easily
Matt
PostPosted: Mon Apr 16, 2012 1:15 pm Up
Trade Rating: +32
That doesn't look any worse than my wheel.
gazza82
PostPosted: Mon Apr 16, 2012 1:26 pm Up
Why don't you swap the front wheels and see if it's the same ...
- if it is you have a suspension/subframe problem
- if it isn't and the other wheel sticks out, it's the wheel and it doesn't match. What did you measure? Hub to outer rim? That's the offset you need to check.
Not got a thin spacer stuck to the back of one?
If you have directional tyres, remember to swap them back before you drive anywhere!
