Latest: lio94
Overall: 17181
Online Now [171]:
Visitors: 170
Today: 101580
Total: 140578644
Forums › The Car › Solved 206 Problems › Immobiliser problems need help asap *SOLVED, Remove thread*
lmilligan
PostPosted: Sat Apr 21, 2012 7:01 pm Up
Can't start my car (cranks but no ignition) fuel pump relay clicks as it should. No lights work, checked all fuses but nothings blown, radio doesn't turn on and mfd won't turn on properly but reads immobiliser fault. Can someone help me out? It's a 2005 2.0 hdi and yes I've searched and shutdown bsi correctly and soft booted and still nothing.
PostPosted: Sun Apr 22, 2012 1:26 am Up
Changed your key?
lmilligan
PostPosted: Sun Apr 22, 2012 3:23 am Up
Now solved, it was the radio fuse in the fuse box under steering wheel. My mate said he checked all of them when he didn't! End thread Smile !!
PostPosted: Sun Apr 22, 2012 4:51 am Up
Why do you want this thread removed?
Surely it's best to leave it here for future reference when somebody else has the same problem?
lmilligan
PostPosted: Sun Apr 22, 2012 5:41 am Up
I was thinking of making a better one later with the symptoms and how to fix it. Hence why I said I end it.
