Online Now [542]:
Visitors: 541
Today: 70927
Total: 105512915
Forums › The Car › 206 Talk › brake fluid
brake fluid
Chris180
PostPosted: Sat Apr 21, 2012 9:18 am Up
busy buying some bits and pieces needed for fitting my new brembos soon,
can anybody tell me how much brake fluid the 180 holds?
2003 aegan blue gti 180 - CatCams 804's camshafts - CatCams vernier pulley - R.S.Tuning remap
Gti 180 Project Thread
PostPosted: Sat Apr 21, 2012 10:03 am Up
500ml bottle
PostPosted: Sat Apr 21, 2012 10:58 am Up
1 litre from Unipart is less than £5!
RallyGTI
PostPosted: Sat Apr 21, 2012 12:30 pm Up
I run my Road Rally car on DOT 5.1 as I found I was getting brake fade with DOT 4.1.
DOT 5.1 has a higher boiling point and less chance of breaking down.
GTI is ready
