Latest: morgan20
Overall: 17135
Online Now [1004]:
Visitors: 1003
Today: 74202
Total: 110626173
Forums › The Car › 206 Talk › 106gti cam?
106gti cam?
heyziq
PostPosted: Thu Apr 19, 2012 10:23 am Up
i want to purchase this, but i need confirmation, is it pug and play?
need valve spring and also do i need pulley change?
heyziq.com
PostPosted: Thu Apr 19, 2012 10:41 am Up
To fit on a 206? I think the heads are different.
PostPosted: Thu Apr 19, 2012 10:59 am Up
i remember is plug and play; have seen people fitting saxo vts cam on their 206
but i will be surprise if you can gain anything at all.
heyziq
PostPosted: Thu Apr 19, 2012 12:52 pm Up
[quote="Seabook"]i remember is plug and play; have seen people fitting saxo vts cam on their 206
but i will be surprise if you can gain anything at all.[/quote
some say 140 hp but with valve spring, remap too
heyziq.com
PostPosted: Thu Apr 19, 2012 1:51 pm Up
i am not sure where did you got your information from but that's not what i have been seen from RR, although you could argue the car might have run poorly or bad remap.
and i start to recall you might have to drill and tapped the head to fit the inlet cam.....
heyziq
PostPosted: Sat Apr 21, 2012 10:29 am Up
so how if i put larger throttle body
heyziq.com
