Latest: ArtistKS
Overall: 17145
Online Now [385]:
Visitors: 384
Today: 3066
Total: 116140131
Forums › The Car › 206 Problems › clutch cable or gearbox
Tam80
PostPosted: Sun Apr 22, 2012 9:56 am Up
jumped in car there to go pick other half up from work...clutch pedal hit the floor with ease...very notchy pedal...can still get gears but bite is as high as it goes without packing up...no slipping from clutch
need help here guys please Confused
206/GT/GTI
PostPosted: Sun Apr 22, 2012 10:03 am Up
gti should use hydraulic clutch
Tam80
PostPosted: Sun Apr 22, 2012 10:19 am Up
just had a quick nosey through threads there...so in other words i am goosed mate ?
206/GT/GTI
Tam80
PostPosted: Sun Apr 22, 2012 1:26 pm Up
anybody any idea how much longer this will last before it finally gives up the ghost ?
206/GT/GTI
Tam80
PostPosted: Sun Apr 22, 2012 2:47 pm Up
can see my wee gti goin to the big scrappy in the sky then lol
too many probs with it..doin my nut in...last owner musta ragged the a**e aff it
206/GT/GTI
PostPosted: Sun Apr 22, 2012 2:59 pm Up
Don't give up so easily.
If it's hydraulic as Seabook says, it will most likely need toping-up, then find
the leak/problem.
PostPosted: Sun Apr 22, 2012 3:04 pm Up
check this
www.206info.co.uk/Foru...lutch.html
Tam80
PostPosted: Sun Apr 22, 2012 3:20 pm Up
cheers guys will give it a going over tomorrow and see what happens...
206/GT/GTI
Tam80
PostPosted: Sun Apr 22, 2012 3:42 pm Up
the leak/problem.
just thinking here...topping up...is it same reservoir as the brake fluid ?
206/GT/GTI
PostPosted: Sun Apr 22, 2012 11:37 pm Up
Someone else might know as I don't have this on a 1.4i
Tam80
PostPosted: Mon Apr 23, 2012 12:45 am Up
ok no probs mate...was out just there and cant see any leaks...and plenty of fluid there..thats if its same reservoir lol
206/GT/GTI
Tam80
PostPosted: Mon Apr 23, 2012 1:14 am Up
anybody any ideas on where i start here to check if its slave cylinder that is goosed ?
and ermmm...where is my clutch slave cylinder ?
206/GT/GTI
Tam80
PostPosted: Mon Apr 23, 2012 6:49 am Up
just gave the it the works there..no leaks anywhere what so ever...so was fearing the worst until i seen this...now fingers crossed that somebody here will put me wise
hope pic works
[/img]
206/GT/GTI
Tam80
PostPosted: Mon Apr 23, 2012 6:50 am Up
[img]
[/img]
206/GT/GTI
PostPosted: Mon Apr 23, 2012 6:52 am Up
Is that an actual leak?
Can't tell from the pic.
