Online Now [67]:
Visitors: 67
Today: 21727
Total: 104972059
Forums › The Car › 206 Problems › Identifying pipe/ducting that has fallen from my car...
c128
PostPosted: Mon Apr 23, 2012 5:40 am Up
I found the following hanging from underneath my 2001 diesel 206 2.0 HDI, to the right of the radiator as you face the front, about a month ago:
It wasn't attached to anything so, in case I lost it driving off, I just pulled it out from where it had been caught and said to myself "better have a look and find out what this is and where it has come from in case it's serious". Then I forgot all about it, but here I am now Smile .
Anyway, I've just found it again a month or so on and the car seems to have been running fine since it came off - from a quick look over and under I can't see where it has come from either. I'm suspecting it might come from air filter ducting or something like that, but that's just a wild guess.
Anyone know what it is and whether I should be worried that it's no longer attached?
c128
Jack4273
PostPosted: Mon Apr 23, 2012 5:52 am Up
I think thats just a part of the original cold air feed, could be wrong tho
Clarion VZ409E 7 inch DVD motorised screen
Sony XMZ-R604 440 watts Channel Amplifier
Vibe Slick 12" 1200 watt Subwoofer
Pioneer TS-A6903i 6 x 9 3-way 350 watts
Raceland 4-2-1 Stainless Steel Manifold
Remapped Ecu
Wolfrace Street Hustle 17"
Very Happy
Click For Da WIP! 206info.co.uk/Garage/m...d=336.html
mattvaretto
PostPosted: Mon Apr 23, 2012 6:09 am Up
That's what I thought looks like cold air feed pipe.
c128
PostPosted: Mon Apr 23, 2012 6:11 am Up
Just realised that the pictures don't really show scale - it's not really that big.
Here's another angle with a 2p coin in view:
The round end (facing) in the above picture has lugs that suggest it twists into something to lock into place - dunno what though...
c128
mattvaretto
PostPosted: Mon Apr 23, 2012 6:16 am Up
Have you looked under the car and seen if it looks like there's anything missing?
c128
PostPosted: Mon Apr 23, 2012 6:19 am Up
Yep - I had a quick look over and under and unfortunately I can't see anywhere obvious where it might have come from.
I haven't had a detailed look though - just wondered if anyone could identify it straight away as something really obvious.
If it's likely something to do with the cold air intake, from what others have suggested, then I guess a good look over from the right-hand side in and around the air filter is in order.
c128
PostPosted: Mon Apr 23, 2012 6:27 am Up
It's either the air intake, or the battery cooling pipe, both fit by right hand side of the radiator.
Abzynthe
PostPosted: Mon Apr 23, 2012 6:35 am Up
East Area Rep - Abzynthe
Looks like this bit. I know its not a 2.0hdi but the battery area is the same
c128
PostPosted: Mon Apr 23, 2012 9:23 am Up
Thanks - does look similar.
The car's out today but I'll check today or tomorrow around the battery and air filter box - lots of Googling for images based on air intake etc., based on the above, doesn't seem to throw up anything that looks the same...
c128
c128
PostPosted: Wed Apr 25, 2012 6:00 am Up
Full marks to those that mentioned the battery Smile .
This isn't a picture of my car, as I haven't removed the bumper, but looking down from above it looks to be this:
...at least, I have nothing attached there from the fan, and the pipe that does come from the battery box connects to nothing further down.
Just trying to see if I can refit it without removing anything I don't need to.
c128
