Online Now [116]:
Visitors: 115
Today: 36901
Total: 138827194
Forums › The Car › 206 Talk › Airbag Removal
Airbag Removal
Phasmatic
PostPosted: Tue Apr 24, 2012 3:33 pm Up
Hi, i have recently purchased a replacement steering wheel for my 206 which came to me with the air-bag attached. I CANNOT for the life of me figure out how I'm meant to get the air-bag off. I know I have to do something with the metal clip inside the hole but I cannot figure it out. Am I meant to push it forwards/backwards/straight down? Everything I have tried so far hasn't worked! any advice would be greatly appreciated!
Hi!
Jensen
PostPosted: Tue Apr 24, 2012 3:41 pm Up
isnt there just a fer torx to get the front of the steering wheel then a few cables to unclip ?
PostPosted: Tue Apr 24, 2012 3:42 pm Up
Did you buy the right one?
Screw on or clip on?
Mux or non-mux?
anton1989
PostPosted: Tue Apr 24, 2012 3:53 pm Up
Trade Rating: +16
mine just had 2 torx at the back?
PostPosted: Tue Apr 24, 2012 3:55 pm Up
Yours is non-plexed.
Jensen
PostPosted: Tue Apr 24, 2012 4:01 pm Up
I took one of a plexed gt today and that had two torx at the back aswell, confused much ha!
anton1989
PostPosted: Tue Apr 24, 2012 4:05 pm Up
Trade Rating: +16
i got my gti steering wheel from a plexed though and it came of the same way?
Phasmatic
PostPosted: Tue Apr 24, 2012 4:12 pm Up
Mine is a multip[lexed steering wheel so its just one hole for the airbag clip behind the vertical stalk. Just cant see how that clip is meant to release the airbag....
Hi!
PostPosted: Tue Apr 24, 2012 4:13 pm Up
A plexed GT? That is new.
Jensen
PostPosted: Wed Apr 25, 2012 1:14 am Up
Had all the digital display and bigger top clock bit so I'm assumin it was
Jensen
PostPosted: Wed Apr 25, 2012 1:18 am Up
Maybe it's not plexed ha my Bad!
PostPosted: Wed Apr 25, 2012 1:51 am Up
It wasn't plexed. A GT was only made until 2000
deacon49
PostPosted: Wed Apr 25, 2012 2:11 am Up
The hole in th bottom of the wheel has a wire inside. You may need someone else or find a way to hold the steering wheel tight because on mine I swapped out the standard wheel for a GTI one and I put a flat blade screw driver across the wire and gave it a firm but quick knock towards the centre of the wheel.
Quick word of warning as it happened to me... Once you get the bolt out the centre of the wheel and your knocking the wheel off the column watch out for the airbag and horn wires. I thumped the back of the wheel towards me sat in drivers seat and as it came off it ripped the plugs off the airbag Sad
Hope this helps
Will
Phasmatic
PostPosted: Wed Apr 25, 2012 8:03 am Up
Cheers for that Deacon, ive now got it off! Didnt realise i had to put force on the wire square on. Now to get the old steering wheel off.
Hi!
