Posted: Tue Jul 03, 2012 12:00 pm |
hi im new to the 206 gti but i have owned a 205 gti befor
1.at the moment im finding it hard to move the gear stick in gos in to
gear fine but moving it around is difficult even in neutral
2.after about 5mins of diving it seams to be reving at 2000rpm on tick over
any ideas
| | ![](images/spacer.gif) |
Posted: Tue Jul 03, 2012 12:03 pm |
Hello.
1. Check the linkages are greased
2. Clean the ICV
Posted: Tue Jul 03, 2012 1:03 pm |
i would check the oil...
did you just buy the car?
Posted: Tue Jul 03, 2012 1:07 pm |
yes got it cuple of days ago . the gears seem to get harder as it warms up
Posted: Tue Jul 03, 2012 1:09 pm |
did your clutch working fine?
Posted: Tue Jul 03, 2012 1:11 pm |
yes clutch is fine
Posted: Tue Jul 03, 2012 2:11 pm |
does it make any different when the engine is off?
Posted: Tue Jul 03, 2012 2:37 pm |
Seabook wrote: |
does it make any different when the engine is off? |
dont think so its easy when its cold
Posted: Tue Jul 03, 2012 2:41 pm |
tommy87 wrote: |
Seabook wrote: |
dont think so its easy when its cold |
Wrong oil in gearbox i'd say. Should 75w80.
Posted: Tue Jul 03, 2012 2:44 pm |
Steve206 wrote: |
tommy87 wrote: |
Seabook wrote: |
Wrong oil in gearbox i'd say. Should 75w80. |
if that's the case it should be the otherway round
i would have though is more likely to be clutch issue (cylinder)
Posted: Tue Jul 03, 2012 2:59 pm |
Seabook wrote: |
Steve206 wrote: |
tommy87 wrote: |
Seabook wrote: |
i would have though is more likely to be clutch issue (cylinder) |
Im sure Edward had this problem when he put wrong oil in. Slave culinder would make it hard to engage gears, but not move the stick.
Posted: Tue Jul 03, 2012 3:26 pm |
even in neutral its stiff with out the clutch engaged
