Posted: Sat Apr 28, 2012 5:37 am |
right... so last night i was driving home and i switched to second and noticed that when i put my foot down it was like wheel spinning or something and was revving up to the limiter with hardly any revs, making a screeching noise too when i wanted to pull away, so i stopped and turned it off then back on and went to put it in gear and took my foot off the clutch and nothing, no stalling no drive, nothing! put it into revers was absolutely fine, the clutch seems fine too, could this be my gearbox!
Posted: Sat Apr 28, 2012 6:02 am |
"was revving up to the limiter with hardly any revs"
what do you mean by this?
did you only tried 1st gear? what about 2,3,4 and 5?
Posted: Sat Apr 28, 2012 6:05 am |
1st, 2nd and maybe a bit of third it seemed like the more torque there was the more it would do it if that makes sense?
Posted: Sat Apr 28, 2012 7:04 am |
Not what I was expecting when I saw the title
Posted: Sat Apr 28, 2012 7:27 am |
Ha Ha, defo not what I thought it was going to be about with the title!
| - Sinature removed due to size.
Please feel free to upload one of the correct dimensions. | |
Posted: Sat Apr 28, 2012 7:37 am |
ahahah!:L
Posted: Sat Apr 28, 2012 8:16 am |
Drain your gearbox oil that should give you a clue as to whats wrong. Your discription sounds like clutch fail and then like a gear box death dependong how i read it.
Posted: Sat Apr 28, 2012 10:57 am |
Gearboxes are prone on 206's aswell
Posted: Sat Apr 28, 2012 1:18 pm |
Well somebody had too!!
Posted: Sat Apr 28, 2012 2:27 pm |
Sometimes the crown of the differential (big cog) has split when it does what you describe.
Especialy screeching sound and then sudden no-drive. Hope it's not that..
Posted: Sat Apr 28, 2012 4:06 pm |
V9977 wrote: |
Especialy screeching sound and then sudden no-drive. Hope it's not that.. |
diff is cheap and is easy to replace
Posted: Sat Apr 28, 2012 5:03 pm |
Posted: Sun Apr 29, 2012 3:22 am |
yes, second hand that's what i mean.
totally forget in the MA box, the crown wheel are press on
Posted: Sun Apr 29, 2012 3:51 am |
I was expecting this....
Or this...
Posted: Sun Apr 29, 2012 4:34 pm |
omg crying!:L and yeah hope its not the gearbox
