Latest: Stu-mill
Overall: 17131
Online Now [307]:
Visitors: 306
Today: 5226
Total: 104814094
Forums › The Car › 206 Talk › tranny problems! :(
tranny problems! :(
Adam2061994
PostPosted: Sat Apr 28, 2012 5:37 am Up
right... so last night i was driving home and i switched to second and noticed that when i put my foot down it was like wheel spinning or something and was revving up to the limiter with hardly any revs, making a screeching noise too when i wanted to pull away, so i stopped and turned it off then back on and went to put it in gear and took my foot off the clutch and nothing, no stalling no drive, nothing! put it into revers was absolutely fine, the clutch seems fine too, could this be my gearbox! Sad
206 1.6 owner
PostPosted: Sat Apr 28, 2012 6:02 am Up
"was revving up to the limiter with hardly any revs"
what do you mean by this?
did you only tried 1st gear? what about 2,3,4 and 5?
Adam2061994
PostPosted: Sat Apr 28, 2012 6:05 am Up
1st, 2nd and maybe a bit of third it seemed like the more torque there was the more it would do it if that makes sense?
206 1.6 owner
Jammie_1989
PostPosted: Sat Apr 28, 2012 7:04 am Up
Not what I was expecting when I saw the title Laughing
206 gti 180
nellyhaggis
PostPosted: Sat Apr 28, 2012 7:27 am Up
Ha Ha, defo not what I thought it was going to be about with the title!
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
Adam2061994
PostPosted: Sat Apr 28, 2012 7:37 am Up
ahahah!:L
206 1.6 owner
parkesie
PostPosted: Sat Apr 28, 2012 8:16 am Up
Drain your gearbox oil that should give you a clue as to whats wrong. Your discription sounds like clutch fail and then like a gear box death dependong how i read it.
Signature p**s
Jensen
PostPosted: Sat Apr 28, 2012 10:57 am Up
Gearboxes are prone on 206's aswell Sad
PostPosted: Sat Apr 28, 2012 1:18 pm Up
Well somebody had too!!
PostPosted: Sat Apr 28, 2012 2:27 pm Up
Sometimes the crown of the differential (big cog) has split when it does what you describe.
Especialy screeching sound and then sudden no-drive. Hope it's not that..
PostPosted: Sat Apr 28, 2012 4:06 pm Up
diff is cheap and is easy to replace Laughing
PostPosted: Sat Apr 28, 2012 5:03 pm Up
Not the crown isn't.
Unless you are talking second-hand one.
It becomes un-stuck from the housing at the seam here:
And costs quite a bit new. Or you can spot-weld it. Smile
PostPosted: Sun Apr 29, 2012 3:22 am Up
yes, second hand that's what i mean.
totally forget in the MA box, the crown wheel are press on Laughing
PostPosted: Sun Apr 29, 2012 3:51 am Up
I was expecting this....
Or this...
Adam2061994
PostPosted: Sun Apr 29, 2012 4:34 pm Up
omg crying!:L and yeah hope its not the gearbox Sad
206 1.6 owner
