Online Now [170]:
Visitors: 169
Today: 58896
Total: 138849095
Forums › The Car › 206 Problems › 2nd gear crunch
2nd gear crunch
Jammie_1989
PostPosted: Tue May 15, 2012 1:53 am Up
My car every now and again crunches when putting into second gear. Sometimes happens when higher up the rev range and sometimes lower. Guessing the gearbox will need 2nd gear replacing but dont know much about gear boxes.
Also my clutch is on the way out. Would this make any difference?
Hope isnt not a full gearbox rebuild Sad
206 gti 180
-Dave-
PostPosted: Tue May 15, 2012 2:36 am Up
Trade Rating: +36
Get your clutch sorted then still see if you have the problem. No point in worrying about that while you have a dodgy clutch.
Ex 206 Owner.
PostPosted: Tue May 15, 2012 3:32 am Up
New clutch time, I had this problem in my GTi when my clutch was on the way out.
PostPosted: Tue May 15, 2012 3:34 am Up
Could well be clutch related but I would say 2nd gear synchro-ring naffed.
And/or incorrect gearbox oil.
Jammie_1989
PostPosted: Tue May 15, 2012 5:52 am Up
Maybe not a new box then Smile Get a nice clunking when changing from 1st to 2nd as well and clutch judder. Machanic I go to said its cause its nearly gone and they go harder or something at end of their life. Said the flywheel was fine so hopefully new clutch soon will solve the problem Smile
206 gti 180
