Forums › The Car › 206 Problems › Do I need Planet Peugeot to bleed non multiplexed brakes? |
Posted: Mon Apr 30, 2012 2:10 pm |
As you may know my 206 has been completely taken apart during the winter. Rear brake pipes have been replaced right through to the ABS unit.
Before the pipes were filled with fluid I switched the ignition on. Even now the ABS light is on all the time.
I believe the pedal might be slightly spongey too even though I've bled the brakes with an easibleed kit. I'be not been able to drive the car yet to check them thoroughly.
I could have damaged an ABS sensor while everything was apart but could I just need to bleed the brake using Planet Peugeot?
Posted: Mon Apr 30, 2012 2:37 pm |
No you don't.
Posted: Mon Apr 30, 2012 11:39 pm |
Good stuff. Thanks.
Posted: Fri May 04, 2012 8:27 am |
If the ABS light is still on with the engine running you might find it just needs to go down the road to knock it off. I know my dad's evo whenever we have that up on axel stands it allways throws the ABS light on untill it's gone down the road.
Posted: Fri May 04, 2012 9:26 am |
I'll see how it goes. It's been driven a short distance today but it's still on. Might need a longer drive. Should be too big a problem anyway. Brakes feel fine now.
