Latest: Kifi69
Overall: 17183
Online Now [438]:
Visitors: 437
Today: 88024
Total: 144547804
Forums › The Car › 206 Problems › Creaking sounds from front when turning full lock/incline
jimjam19927
PostPosted: Thu May 10, 2012 3:42 pm Up
As the title says: When I full lock, heavy turn or am on a incline normally quiete large the front makes a sort of creaking sound. Its not a knocking or banging or scrapping its definately a creek Razz
I have Gaz Coilovers with new droplinks and topmounts when fitted about a year ago possibly?
I have had the car full locked and tried to pull everything I can see to see if anything is loose but no luck and no obvious stuff in the wrong place. I had these fitted by a mechanic as I dont touch things that are in the hands of my life Razz
Hope someone can help thanks see you at mod nats!
Member: 685
I Over Use Smilies Razz
hayes_ctfc
PostPosted: Fri May 11, 2012 1:45 am Up
Top strut bearing could be worn or there could be some play in it maybe? Mine ha a horrible noise coming from the near side because of that
OLD: Peugeot 206 2.0 GTi 138
NEW: Seat Leon FR TDi 170
jimjam19927
PostPosted: Sat May 12, 2012 11:42 am Up
Any other help? Smile
Member: 685
