Posted: Mon May 07, 2012 3:51 am |
URGENT!
Has anyone done one before? Im having problems trying to allign the hub. Does the track rod end need to be taken off?
| | ![](images/spacer.gif) |
Posted: Mon May 07, 2012 3:58 am |
Its a total b***h! I found it easier with another pair of hands. Try to jack the hub up this will give you more room to play with. My car isnt lowered, so i also tightened up my springs with exhaust clamps. no need to remove the track rod.
Posted: Mon May 07, 2012 4:01 am |
Im assuming your changing the whole wishbone?
Posted: Mon May 07, 2012 4:21 am |
Im replacing the driveshafts. I cant seem to get the hub in line. When I jack the hub up it keeps moving off centre. Would using spring clams help?
Posted: Mon May 07, 2012 4:48 am |
Get two people so one can pressure the driveshaft in. and keep trying may take a while
I never use a jack, just pops it out of alignment, just line it up until it's nearly in then tap it with a hammer
Posted: Tue May 08, 2012 1:53 am |
Managed to do it by using spring clamps. Compressed the spring enough for me to align the hub and ball joint. Goes in alot easier than it comes out.
Posted: Tue May 08, 2012 11:15 am |
Steve206 wrote: |
Its a total b***h! I found it easier with another pair of hands. Try to jack the hub up this will give you more room to play with. My car isnt lowered, so i also tightened up my springs with exhaust clamps. no need to remove the track rod. |
Meant to say spring clamps, not exhaust!
Posted: Tue May 08, 2012 11:38 am |
I paid a mechanic £40 to change both. Not worth the hassle.
