Latest: Beduff1977
Overall: 17134
Online Now [589]:
Visitors: 588
Today: 99632
Total: 107089570
Forums › The Car › 206 Talk › Oil change/level
Oil change/level
andyleep
PostPosted: Mon May 14, 2012 1:48 pm Up
I have just done the first oil and filter change on my 180. I put just over 4.5 litres in and thought I'd check the level - the dash has six squares which means it is full! I thought they were supposed to hold 5.5?! The dipstick is showing that the level is above the maximum mark (but I have a feeling that it could be the wrong one). Opinions?
PostPosted: Mon May 14, 2012 1:52 pm Up
always depend on the dipstick to check the level of oil,because the digital one can not accurate sometimes,does it blink with the (Max) on the right,or not?
andyleep
PostPosted: Mon May 14, 2012 1:57 pm Up
No, it doesn't flash. Just have the six squares up for 10 seconds, with the min and max illuminated. So that would say to me it is at the maximum level, but not too high
PostPosted: Mon May 14, 2012 2:02 pm Up
The dipstick is showing that the level is above the maximum mark,right?
how much above the level,alot just few mm?
andyleep
PostPosted: Mon May 14, 2012 2:09 pm Up
I'd say over 10mm! But surely it cant be over the max level when I only put 4.5 litres in?!
PostPosted: Mon May 14, 2012 2:18 pm Up
Don't use the digital one, use dipstick.
Is the car level?
SinfulDesignCom
PostPosted: Mon May 14, 2012 2:20 pm Up
You should only have 4.5 litres in there... Any more and it will swell and blow out the gaskets. The dipstick is the best indication obviously but wait until the oil has settled in the sump before reading - it will take time to settle after you have just put the oil in or gone for a drive...
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
andyleep
Yep! What does a gti 180 dipstick look like?
SinfulDesignCom
PostPosted: Mon May 14, 2012 2:21 pm Up
Bit o' metal with a yellow ring thingy on t'other end Very Happy
andyleep
PostPosted: Mon May 14, 2012 2:26 pm Up
Mine is a green end (not a ring type).........
PostPosted: Mon May 14, 2012 2:29 pm Up
A dipstick is a dipstick... If you don't know what it looks like or where it is on your car. Don't try a DIY oil change, or even better, don't own a car.
It is a possible question on the drivibg test nowadays. Simple basic knowledge.
andyleep
PostPosted: Mon May 14, 2012 2:34 pm Up
I know what a dipstick is. I also know that different engines have different dipsticks so "a dipstick is a dipstick" (as you put it) is not correct. I'm just trying to establish if I have the correct one for a EW10J4S engine as, if it isn't, the reading is likely to be false
PostPosted: Mon May 14, 2012 2:41 pm Up
Only one thread needed for the same subject.
broadblaster
PostPosted: Mon May 14, 2012 2:43 pm Up
According to the owner’s manual the regular 2.0L engine found in the GTi and the CC requires 4.25 litres of oil when changing the oil and filter, and the GTi180 requires 5.3 litres of oil for the same task. The manual is also quite strict on the use of 5W40 synthetic oil only for the GTi180
on a back road playing
SinfulDesignCom
Think you will find Peugeot part numbers will be different so little point speaking to dealer, so...
Get yourself to a scrapyard and compare... Smile
