Latest: tbafonso
Overall: 17130
Online Now [41]:
Visitors: 41
Today: 12089
Total: 103834415
Forums › The Car › 206 Talk › 180 Responsiveness
180 Responsiveness
Jammie_1989
PostPosted: Tue May 15, 2012 6:00 am Up
Should the 180 be extremely responsive to the throttle? Mine doessn't seem to have much urgency. Seems a bit strange as my mums 1.4 206 throws you in the seat if the quickly tap the peddle but then loses all power due to the 1.4 but my 180 doesn't. If I remember my celica was the same where it didnt feel as responsive.
Is it due to all the additional sensors and being a bigger engine? Or is there something I can do?
Its just had a service and I've cleaned the VVT Solenoid
206 gti 180
Jammie_1989
PostPosted: Tue May 15, 2012 6:05 am Up
Just found the other thread I tried to search for and thing its just an electronic vs cable thing.
206 gti 180
PostPosted: Tue May 15, 2012 6:08 am Up
LOL 1.4 throwing you into the seat... only time that happens is if you get rear ended
Jammie_1989
PostPosted: Tue May 15, 2012 6:09 am Up
Haha you know what I mean just the initial throttle if to jerk on the throttle. My 180 just seems a bit of a let down in the throttle
206 gti 180
PostPosted: Tue May 15, 2012 11:35 am Up
The throttle will only open so fast with the motor controlling it...
PostPosted: Tue May 15, 2012 11:53 am Up
Could be worse, could be a newer 206 TU3 with fly by wire throttle & higher road tax Laughing
