Latest: flipflap
Overall: 17140
Online Now [191]:
Visitors: 190
Today: 100911
Total: 113900705
Forums › The Car › 206 Talk › Ball joint rubber dust seal boot
rick-gti
PostPosted: Mon May 14, 2012 1:53 am Up
Has anyone ever changed one of these on the lower wishbone ball joint?
clio 197sport owner
usher
PostPosted: Mon May 14, 2012 12:34 pm Up
service box list them seperate so assume you can there couple of quid
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
gazza82
PostPosted: Mon May 14, 2012 12:41 pm Up
Depends how long it's been split ... a few days is long enough to get dirt and grit in which starts to wear away at the balljoint itself ...
D4NTP
PostPosted: Mon May 14, 2012 12:59 pm Up
Mines had the boots changed. I had two new arms fitted then had it lowered....they bust the boots doing it and replaced them after a few days. Been fine since.
rick-gti
PostPosted: Mon May 14, 2012 1:11 pm Up
Yeah I put a new wishbone on and the hub slipped and split the boot seal. I have found them on ebay and you can secure them on with the small cable ties. Got that to do this friday, new cv boot and track rod ends.
clio 197sport owner
usher
PostPosted: Mon May 14, 2012 3:25 pm Up
i would just go to a dealer for the sake of a few quid also the boot is held on with metal ties for a reaso
project thread WIP
garage
FAQ
206 gti firedance
Dodgernator
PostPosted: Mon May 14, 2012 6:32 pm Up
I didn't think they had boots on the wishbone. I know they have a cover on when new, but you take it off before fitting it. Unless you mean something completely different and I've got the wrong end of the stick.
gazza82
PostPosted: Tue May 15, 2012 2:55 pm Up
There's a rubber boot over the balljoint ... if new, it comes with a protective plastic cover to stop the rubber getting damaged. That's the bit you take off and bin.
