Latest: airmastertapes
Overall: 17133
Online Now [62]:
Visitors: 61
Today: 13535
Total: 106677778
Forums › The Car › 206 Talk › hard gear change?
hard gear change?
gaffa786
PostPosted: Tue May 15, 2012 1:52 pm Up
hi, another problem (i think).
basically when i try putting my car into first gear it gets really difficult and i have to really push it up. sometimes it is ok though like if i put it into 3rd and then straight into first it goes in smoothly but not all the time.
been having too many problems with my car Sad
Davies
PostPosted: Tue May 15, 2012 2:05 pm Up
This is a 206 issue,
Happens to me on my 1.1, just what it does :), Cant get into 1st unless im under around 10 - 5 mph :).
I think of it as a way of me stopping ripping out my gearbox!
Poppy, My 2.0 HDI Dream Wink
PostPosted: Tue May 15, 2012 2:29 pm Up
what speed are you doing when you want to get into 1st?
PostPosted: Tue May 15, 2012 2:32 pm Up
Anything other than an absolute crawl will ruin the gearbox.
gaffa786
PostPosted: Tue May 15, 2012 2:34 pm Up
At a standstill normally like at traffic lights it is hard to put into first. i dont use 1st other than to move off from a stand still
PostPosted: Tue May 15, 2012 2:41 pm Up
give a fit of rev in neutral and it will slide into first easily
gaffa786
PostPosted: Tue May 15, 2012 2:47 pm Up
meaning give it bit of gas while putting into first?
PostPosted: Tue May 15, 2012 3:13 pm Up
Learn to drive.
gaffa786
PostPosted: Tue May 15, 2012 3:21 pm Up
Lee wrote:
Learn to drive.
I can its got nothing to with driving. Im at a standstill and just putting it into first gear
karimali831
PostPosted: Tue May 15, 2012 4:38 pm Up
It's normal, just leave it in gear two and rev when you need and put it in gear 1 only when pulling off.
206 GTI 180
riddler118
PostPosted: Wed May 16, 2012 12:52 am Up
gaffa786 wrote:
Lee wrote:
Learn to drive.
lol im learning to drive at the moment and asked my instructor about this issue with my 03 206 he said something about resistance stopping me going into first from say 3rd and launching myself through the windscreen
still a learner driver with no knowledge of car workings or modding please be nice lol
PostPosted: Wed May 16, 2012 6:17 am Up
yes
DeadEyePaul
PostPosted: Wed May 16, 2012 6:22 am Up
You might need a gearbox oil top up or oil change? When did you last get a service done dude?
PostPosted: Wed May 16, 2012 9:06 am Up
gear oil was never included in car service for peugeot 206
gaffa786
PostPosted: Wed May 16, 2012 11:13 am Up
Had my car serviced in march this year.ni had my driveshaft replaced and the garage put some gearbox oil in aswal but did not drain the old oil out they jus topped it up by squirting it in somewhere under the car
