Latest: tbafonso
Overall: 17130
Online Now [64]:
Visitors: 63
Today: 110
Total: 104124938
Forums › The Car › 206 Problems › Door stuck :/
Door stuck :/
Jammie_1989
PostPosted: Sat May 19, 2012 8:37 am Up
Just as I sorted everything out the door has decided to stick. It won't open from outside or inside so I can't even remove the panel to have a look.
Any ideas what might be causing this. It's under warranty so if it isn't an easy fix will be going back to the dealer to sort out.
206 gti 180
iainlovatt
PostPosted: Sat May 19, 2012 8:42 am Up
a faulty lock perhaps what happens when you put the key into the lock manually? Try turning the key in the lock and pulling on the handle?
(My Garage)
Jammie_1989
PostPosted: Sat May 19, 2012 8:43 am Up
Doesn't do anything the lock goes up and down with the key and with the remote but the actual catch wont open. There must be something inside which has worn or broke. Shouldn't have to pay for it though so will send it back as I think to open it I will need to break into the car.
206 gti 180
iainlovatt
PostPosted: Sat May 19, 2012 9:03 am Up
try this clicky
(My Garage)
