Latest: Stu-mill
Overall: 17131
Online Now [579]:
Visitors: 578
Today: 43075
Total: 104851918
Forums › The Car › 206 Problems › Electrical Issues
Electrical Issues
PostPosted: Fri May 18, 2012 5:02 am Up
Ive recently had a few problems and finally had chance to get them posted up
Firstly: This problem must be down to my blower motor i think but when im driving around town my blowers wont come on but as soon as ive been on the motorway for around 5 mins they come on :S also its showing on my display that the heat is like 60 degrees which obviously is not correct
Secondly: Since i have had a ball joint arm changed at a garage my ABS light has come on and always makes a noise when the ignition is turned on
Thirdly: I had to brake slightly harder than usual the other day due to some t***er cutting me up, as soon as i braked my car totally cut out, once turned back on everything had reset itself
If this helps i can occasionaly hear a clicking noise from under the engine
Thanks for any help and advice
Big_Rich180
PostPosted: Fri May 18, 2012 7:20 am Up
Could the garage that fitted the ball joint arm have knocked the ABS sensor cable out of the sensor?
You could check that by jacking the car up and look on the CV joint area and while your there check the ABS ring for damage too.
PostPosted: Fri May 18, 2012 3:41 pm Up
I'll have a look tommorow cheers Rich
Can anyone shed any light on the other issues?
Ash
PostPosted: Sat May 19, 2012 5:20 am Up
Third sounds like a loose wire, probably earth strap.
