Posted: Mon May 21, 2012 11:46 am |
has anyone on here done this and what should i do/not do when doing this? i need to take of 5mm so is this an acceptable ammount?
Posted: Mon May 21, 2012 11:50 am |
This is a joke yes?
| 206 180 rally car in progress. I may not be perfect but there are parts of me that are f£%$ing brilliant | |
Why can't you just space the wheels slightly to clear the calipers?
| Project Low and Slow.. Going Euro for 2013. Keep your eyes peeled, big plans ahead..
See my project here. | |
Posted: Mon May 21, 2012 11:53 am |
they have 20mm spacers on at the moment and i want the front to sit in a bit. its not a joke, a few people i know have done it, but i didnt know if it was "too" dangerous, despite the obvious :-p.
Posted: Mon May 21, 2012 11:56 am |
i wouldnt, because i value my ability to brake
Posted: Mon May 21, 2012 12:01 pm |
i know it wasnt the most sensible question but people do it and im just after someone who has done it to give me some feedback.
Posted: Mon May 21, 2012 12:09 pm |
I've heard of people 'grinding' a fabricated bracket used so a calipers from outher cars will fit.
NEVER a caliper as it will weeken it and could fail/crack under the pressure.. you'll have no brakes
Posted: Mon May 21, 2012 12:16 pm |
what brakes and wheels you trying to use
im up for some stupid ideas to get things to work but this is insanity you cant see how much you have taken off or how much is left if you was to machiene them maybe but 5mm is way too much to considder
especially when you can get enough braking power form the 180 discs
Posted: Mon May 21, 2012 12:18 pm |
Trim it down and find out, if we dont hear from you in next few weeks we just presume your dead
Posted: Mon May 21, 2012 12:20 pm |
It's doable...I did it with a set of GTi6 calipers under a set of banded rallye steelies on my S2 Rallye when I had it sitting on it's a**e. Basically ground the bits that come out like little humps down and just chemical metal'd the whole caliper smooth. Was spot on for the entire duration of me having them on the car.
Posted: Mon May 21, 2012 12:24 pm |
you really needed to ask that question?!?
grinding bits off the brakes just to fit wheels is ridiculous and dangerous also if you have an accident and the insurance and/or police spot you've been grinding bits off brakes off you will be in the s*** then
even if you were to do it 5 mm is a lot to take off and will probably weaken them
Posted: Mon May 21, 2012 1:19 pm |
Do it.
Posted: Mon May 21, 2012 1:26 pm |
i would say it doable too, there is 2 bands on the outside of the calliper that could be smoothed down to the middle and it would still be strong enough to work.
But its something that is just stupid to do, any way. why have such smalls wheels that you would need to do such a thing anyway?
| Pug 206 1.4 Hdi
Pug 206 Gti 138 | |
Posted: Mon May 21, 2012 1:45 pm |
| HDI90 wrote: |
| Trim it down and find out, if we dont hear from you in next few weeks we just presume your dead |
Posted: Mon May 21, 2012 1:50 pm |
Its ok everybody, he has the reg of his car on display so that means as long as he is in front of you nobody needs to worry
