Latest: Kifi69
Overall: 17183
Online Now [414]:
Visitors: 413
Today: 111009
Total: 144570698
Forums › The Car › 206 Problems › Knocking after fitting coilovers.
ryan.h
PostPosted: Tue May 22, 2012 3:33 pm Up
Hi everyone, I fitted coilovers to my car at the weekend and everything was fine until last night when it started making a knocking noise over bumps, the drop links seem to be fine and I used my old top bushes which were replaced last year. Does Anyone know what could be the problem?
Cheers Ryan.
Peugeot 206 GTI HDI
PostPosted: Tue May 22, 2012 3:34 pm Up
wishbone?
Jensen
PostPosted: Wed May 23, 2012 12:52 am Up
Ino its a daft question, You sure your got them as tight as they were? Sounds like there moving when your going over bumps tbh, jack it up and see if there's any play in the engine where the bolts are Smile
PostPosted: Wed May 23, 2012 3:38 am Up
Recheck the droplinks, mine always needed a second tighten after changing. More then likely the wishbone though,
usher
PostPosted: Wed May 23, 2012 1:23 pm Up
as mentioned check droplinks mine rattled a day after fitting, they needed 1/8th a turn and all was healed
not sure how you check the wishbone is gone or not as my whole front end knocked over bumps so changed the lot
drop links is more of a rattle over uneven road
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
