Latest: lio94
Overall: 17181
Online Now [127]:
Visitors: 126
Today: 35505
Total: 141053822
Forums › The Car › 206 Problems › any body help???
any body help???
Walton450
PostPosted: Thu May 24, 2012 12:13 pm Up
my 206 has just started making a very loud bannging noise then turning which seens so come from the front left. its like 2 bangs one after the other it doesnt sound good at all. could this be drive shafts, also if you press the back of the car down it hisses on its way back up is this normal????????
I\'m Steve got a 2003 verve.
ARRAN
PostPosted: Thu May 24, 2012 1:07 pm Up
Driveshafts, top mount bearings or wishbones. As for the second question, that doesn't sound normal. Check the struts are lubricated properly?
See my project here.
Walton450
PostPosted: Thu May 24, 2012 1:16 pm Up
have lifted the front end up. there's a definate rattle on the passanger side but i dont no if its coming from the box. i was drive down a dualcarraige way the other day and the was a big bag and i thought i have drive over something and it went into the wheel liner. but now i think this could have been the c.v joint giving up cheers for your advise arran.
ARRAN
PostPosted: Thu May 24, 2012 1:33 pm Up
No problem, jack the car up and check for play. Does the car pull to one side if you give a boot full?
Walton450
PostPosted: Thu May 24, 2012 2:04 pm Up
just had the AA out to have a look. he says the diff has gone and the box is most likey going to need replacing.
PostPosted: Thu May 24, 2012 3:20 pm Up
If the box is otherwise good, you can replace the planet/satelite gears of the differential.
PostPosted: Thu May 24, 2012 3:24 pm Up
i got a spare diff
edit: didn't know you got a 1.1 so can't help you either Laughing Laughing Laughing
