Latest: tbafonso
Overall: 17130
Online Now [333]:
Visitors: 333
Today: 83807
Total: 102820742
Forums › The Car › 206 Talk › daNm torque units?
daNm torque units?
PostPosted: Wed May 23, 2012 5:13 pm Up
Had a google around but not sure:
Is 1.5 daNm = 15Nm for torque units when tightening bolts?
Trust Peugeot to make things complicated.
Cheers.
simpsonrc
PostPosted: Wed May 23, 2012 5:15 pm Up
yes
PostPosted: Wed May 23, 2012 5:20 pm Up
simpsonrc wrote:
yes
Thanks.
In this case, isn't 15Nm quite a low torque for the 6 x clutch plate mounting bolts? Or are the pegs supposed to take the turning power from the flywheel to the plate?
PostPosted: Wed May 23, 2012 5:35 pm Up
can't see the problem...
they are M 8 bolts aren't they?
PostPosted: Wed May 23, 2012 5:41 pm Up
Yep.
Just that garages around here ram them in with an air-gun until rock solid.
However I have a feeling and have now heard they must be torqued evenly as specified by the manufacturer (15Nm for 1.4i) and rely on the pegs for power transmition to the plate, not the bolts. ? Confused ?
oldskoolz
PostPosted: Wed May 23, 2012 5:46 pm Up
power is transmitted through the pegs (dowels) not the bolts
Black 206 Gti. Soon to be 2.2
PostPosted: Wed May 23, 2012 5:55 pm Up
Many thanks for reply.
So that info is correct and raming the bolts to hold the plate on is not really how it's meant to work.
15Nm sounds low, will the bolts make the plate sit properly on the flywheel
or is it acceptable to have a minimal gap, or.. ?
PostPosted: Thu May 24, 2012 2:38 am Up
something might be useful?
www.schaeffler.com/rem...pkw_en.pdf
PostPosted: Thu May 24, 2012 2:54 am Up
Excellent cheers mate. Wink
Should be a sticky me thinks.
