Posted: Mon May 28, 2012 2:15 am |
I have the SP spoiler and every time I open the boot it rams into the antenna...
I want to get a Bi Plane spoiler which will be even higher.
Will I need to remove the antenna or alter the angle?
| 2001 Peugeot 206 2.0 HDi 90 D TURBO in China Blue (98-01) [57 MPG] | |
Posted: Mon May 28, 2012 2:34 am |
Could do with a pic of the new spoiler.
Posted: Mon May 28, 2012 2:50 am |
Thats correct you have the early rear mounted aerial that will hit the spoiler when the boot is open. Peugeot fix was some clear tape on the spoiler.
This is nothing to worry about as the aerial bend, fit the Bi Plane and you will be fine
Posted: Mon May 28, 2012 2:51 am |
Isnt this a common problem with the rear aerial catching the spoiler? My gti aerial is front mounted and the other two i have had where aswell.
Posted: Mon May 28, 2012 2:54 am |
rick-gti wrote: |
Isnt this a common problem with the rear aerial catching the spoiler? My gti aerial is front mounted and the other two i have had where aswell. |
It was when Peugeot moved the aerial to the rear, it was fitted to far back and as such the spoiler would touch it.
As said their fix was some clear tape but its nothing to worry about really its not going to damage it
Posted: Mon May 28, 2012 3:02 am |
Mikey2uk wrote: |
This is nothing to worry about as the aerial bend, fit the Bi Plane and you will be fine |
Thanks for clearing up.
It's strange they would stick the antenna so close to the end anyway...
Posted: Mon May 28, 2012 3:28 am |
The spoiler was an option so when the decided to put the aerial at the back they didnt know.
Posted: Mon May 28, 2012 12:16 pm |
Trade Rating: +59
Fire a OEM stubby aerial on. Problem solved.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Mon May 28, 2012 1:32 pm |
I'm going to fix this problem when I swap my aerial from the front to rear :),because the car with rear aerial looks much better than the front mounted one
Posted: Mon May 28, 2012 1:40 pm |
Mikey2uk wrote: |
ahhhh i was wondering why there was tape on my spoiler
| Ford Focus RS in white of course
filled with all sorts of goodies | |
Posted: Mon May 28, 2012 1:47 pm |
Mine is on rear, got a shark fun aerial and sorted problem
