Online Now [140]:
Visitors: 139
Today: 18980
Total: 139769468
Forums › The Car › 206 Problems › Spoiler coming loose
Andrew
PostPosted: Fri Jun 01, 2012 12:41 pm Up
I had my spoiler fitted at dealers and they bolted and bonded it on. Its slightly wobbly on one side and I'm just wondering how can I get to the bolt to tighten it
My 206 thread
www.detailedbyandrew.com
PostPosted: Fri Jun 01, 2012 12:53 pm Up
Did they definitely bolt it? Seems very strange that both methods have undone.
Andrew
PostPosted: Fri Jun 01, 2012 12:58 pm Up
Definately both I spoken to the guy who done it, any idea how I can get to the bolt?
My 206 thread
-Dave-
PostPosted: Fri Jun 01, 2012 1:21 pm Up
Trade Rating: +36
Access should be gained by moving the black plastic bit in the corner inside the boot Andy. Be careful not to tighten to much.
Ex 206 Owner.
spike_202
If you open the boot up and luck in the corners there is a rubber seal take it off and the bolt should be behind there
**spike's project**
TEAM:+200bhp
Andrew
PostPosted: Fri Jun 01, 2012 1:26 pm Up
Does this piece of plastic have 2 plastic popper clips on? So I can just yank it off?
Having a good look there's a gap between the spoiler and boot and I think they fibbed - no glue there
My 206 thread
PostPosted: Fri Jun 01, 2012 1:32 pm Up
The little plastic 'clips' - There is a little circle in the middle, tap a small )glasses) screwdriver/Nail/paperclip into it, the pin pushes out of the back, the cover then practically falls out.
One slight problem is putting them back in. Never had to, so never tried.
paulspug
PostPosted: Fri Jun 01, 2012 1:41 pm Up
Take it back to the dealers bud Wink
-Dave-
PostPosted: Fri Jun 01, 2012 1:43 pm Up
Trade Rating: +36
This. Or If you still haven't sorted it at FCS let me know and I will sort it out for you there.
Ex 206 Owner.
Andrew
PostPosted: Fri Jun 01, 2012 4:26 pm Up
Thanks guys your help and advice is much appreciated Smile
My 206 thread
Andrew
PostPosted: Sat Jun 09, 2012 9:59 am Up
Got onto this today, pushed the pegs out of those clips, and the two screws on the wobbly side were slack so tightened them up. No more wobbling Smile
Put the pegs back in the outside of the clips and push them back into place when the bit of plastic is back on the tailgate.
I had another look between the tailgate and spoiler in the daylight, they did use glue but it must be soft stuff
My 206 thread
