Latest: lio94
Overall: 17181
Online Now [106]:
Visitors: 105
Today: 126914
Total: 140603662
Forums › The Car › 206 Problems › clicking relay switch
sweeney
PostPosted: Thu May 24, 2012 1:00 pm Up
can anybody,i have a 206 hdi gti, I have a clicking noise coming from fuse box under dashboard,I think its a relay switch but how do i know which one it is. any one had the same probably
PostPosted: Thu May 24, 2012 1:01 pm Up
What makes you think it's a problem?
ARRAN
PostPosted: Thu May 24, 2012 1:09 pm Up
My mums HDi does this, I think its the relay for the indicators flashing when the car is unlocked, as they still flash when you get in. Does it go off after a few seconds?
See my project here.
Squeaker
PostPosted: Thu May 24, 2012 1:16 pm Up
Mine did this when the wipers were about to move.
sweeney
PostPosted: Thu May 24, 2012 1:30 pm Up
the noise only happens when driving it does it all the time
Abzynthe
PostPosted: Thu May 24, 2012 1:34 pm Up
East Area Rep - Abzynthe
I have that too, but everything works, so ive just left it.
spike_202
PostPosted: Thu May 24, 2012 1:48 pm Up
relays do click its how they work,what things have you got switched on or using?
**spike's project**
TEAM:+200bhp
QuArTz
PostPosted: Thu May 24, 2012 4:36 pm Up
Trade Rating: +16
I bet it's the rear windscreen wiper.. lol
Squaddiegav
PostPosted: Thu May 24, 2012 4:38 pm Up
Put your hand on them one by one you can feel them working, when found disconnect and go through all your switches to determine which it is
New pug owner
PostPosted: Thu May 24, 2012 4:41 pm Up
Not a good idea with a multiplexed 206, it could end with an expensive repair bill for a new BSI unit.
spike_202
PostPosted: Thu May 24, 2012 5:45 pm Up
Or you could find witch one it is then use a ref drawing to pin point what it's controlling.....bit safer way
**spike's project**
TEAM:+200bhp
sweeney
PostPosted: Fri Jun 08, 2012 9:03 am Up
thx for all the advice, the problem has been sorted. I just made sure all the fuses were in place there was a couple that was not sat in correctly so hopefully thats sorrted the problem out Smile
