Online Now [563]:
Visitors: 562
Today: 152315
Total: 105878883
Forums › The Car › 206 Talk › 1.4 Coolant Temp
1.4 Coolant Temp
ct-xsi
PostPosted: Fri Jun 08, 2012 3:38 pm Up
Right, just a quick question...
I have just picked up a 2002 1.4 lx for the missis...
On driving it home i noticed the coolant temp gauge ranged from around 80-95...
Then when i got home, i popped the bonnet and had a feel at the top hose.. it was firm, still squeezable though not solid.
I then removed the header tank cap and there was a quick hiss..
I dont think the hiss is anything to worry about, and most likely the pressure in the system is just normal...
Im just paranoid with it being a new car and with regards the temp.. im used to driving my fmic'd hdi which runs at 75 degress all day long..
Does this all sound normal really?
PostPosted: Fri Jun 08, 2012 3:44 pm Up
I would more worry about 75 tbh
80 is norm, do remember the system is actually running at 100+ but doesnt boil due to being pressurised
If you really are worried, add to the coolant to clean the system with non bio washing powder, run till up to temp with the heater on full and then drain, refill with the correct 50 50 mix of water and anti freeze. Then finally bleed the system whilst the vehicle is running
Becareful though the water will obviously be hot
PostPosted: Fri Jun 08, 2012 3:47 pm Up
Thermostat on a TU3 is designed to open at 89 deg C.
Coolant temp gauge should sit around 90 deg C during normal operation.
Diesel engines do run COOLER & take longer to get up to operating temp then petrol ones Wink
ct-xsi
PostPosted: Fri Jun 08, 2012 3:48 pm Up
so 80-95 is ok?
\'02 206 XSi
PostPosted: Fri Jun 08, 2012 3:49 pm Up
ct-xsi wrote:
so 80-95 is ok?
Blunty yes
PostPosted: Fri Jun 08, 2012 3:51 pm Up
ct-xsi wrote:
so 80-95 is ok?
80 is to cold & 95 is just starting to get near the cooling fan cutting in, sounds a bit like a lazy thermostat.
There only about £11 from a Peugeot / Citroen dealer & simple to change.
ct-xsi
i worry thats all Smile
\'02 206 XSi
