Latest: Kifi69
Overall: 17183
Online Now [417]:
Visitors: 416
Today: 43197
Total: 144671240
Forums › The Car › 206 Talk › Rear engine mount
Rear engine mount
Forum Index › 206 Talk
donkeyding
PostPosted: Thu Jun 07, 2012 2:54 pm Up
Evening
When i first bought the csr i replaced the engine mounts.
One under the battery box
2 on the left hand side under the ecu
Now there is another one at the back of the engine bolted to the bulk head! Its a little worse for wear but i can't seem to find it any where.
Any one have a part numer for peugeot as il replace when i get the cambelt done in the next few weeks!
Cheers
Dave
usher
PostPosted: Thu Jun 07, 2012 3:08 pm Up
think the one you are on about is the one that connects to the subframe at the bottom rear think its the tourqe bush something like that
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
SinfulDesignCom
PostPosted: Thu Jun 07, 2012 6:44 pm Up
You will have great fun with that one. The mount is on the same bracket as the intermediate bearing on the drivers side driveshaft - so you will need to split the hub and wishbone, take the driveshaft out (you may need to belt the intermediate bearing in doing so as they get stuck) and then unbolt the bracket - three 16mm nuts if I remember. how sad am I... You might have to unbolt a small heatshield if there is one protecting the bearing from the 'zorst.
You have two bushes - one on the stabaliser arm which is about 15mm diameter and the larger one that sits in the bracket itself which is 70mm. You can get a powerflex bush kit for both for around 30-40 squid. Well worth doing in my opinion. Forget OEM.
You will also need to belt the crap out of the old mounts to get them out of the brackets. Good luck Smile
Sinful Design - web design, graphic design, web apps, hosting...
My 2003 GTi 180 Track Project Thread
Sprotty
PostPosted: Fri Jun 08, 2012 1:32 am Up
I got a powerflex one from larkspeed for £25 well worth it over oem.
Life at full throttle...
donkeyding
PostPosted: Fri Jun 08, 2012 2:01 am Up
Thats not too much of a issue really as i'l be doin it whilst its in the air.
Just had a look on larkspeed and can only fid front anti roll bar bushes
Rear axel bushes etc
Anyone got a link?? Very Happy
Cheers
Dave
Sprotty
PostPosted: Fri Jun 08, 2012 4:28 am Up
PFF50-306 is the part no. Look at the notes towards the top of the page for 206.
It's a 306 engine mount on the gti/180. 70mm one is this same as the 306 front engine mount.
Sprotty
PostPosted: Fri Jun 08, 2012 4:34 am Up
www.larkspeed.com/inde...50306P&a=i
Done on my phone so hope the link works.
usher
PostPosted: Fri Jun 08, 2012 5:07 am Up
is this not the same as the vibra technics mount
project thread WIP
garage
FAQ
206 gti firedance
Sprotty
PostPosted: Fri Jun 08, 2012 6:27 am Up
The powerflex one is polyurethane the vibra tecknics is harder rubber compound.
uttz
PostPosted: Fri Jun 08, 2012 7:10 am Up
very easy diy... hardest part is to get a machine shop to press in the new mount... other than that dont forget the gearbox oil
GTi 180 Obsidian Black
SW 1.6 16v Sahara Yellow
Sprotty
PostPosted: Fri Jun 08, 2012 7:29 am Up
All I needed for the powerflex was some fairy liquid Adblock of wood and a hammer!
Sprotty
PostPosted: Fri Jun 08, 2012 7:30 am Up
A block of wood. ( fat fingers on iPhone )
donkeyding
PostPosted: Fri Jun 08, 2012 7:53 am Up
Cool beans will order one up!!
Sinfuldesign said further up that there were 2??? Is that right if so can i have a link to that too??? Very Happy
Hopeing to get all this sprted alog with the cambelt fresh service and gearbox oil etc before i do a trackday at oulton park on the 26th!!!
Cheers
Dave
Sprotty
PostPosted: Fri Jun 08, 2012 9:43 am Up
There is another one on the dog bone but it's a solid bush, should be fine.
SinfulDesignCom
PostPosted: Sun Jun 10, 2012 9:53 am Up
The PFF50-306 is in two halfs and you can push it in with your hands.
But.. doing this bush unless you replace the bush on the stabiliser arm as well seems a little silly. Powerflex don't do this one - I went with Superpro from PRI Racing
www.priracing.com/prod...unt-bushes
