Forums › The Car › Request a how-to › 206 1.9 2001 Brake Pipe Replacement? |
Posted: Tue Jun 12, 2012 11:41 am |
hello all,
car just failed mot on rear brake pipe being corroded, im wondering if any one could share a little information on how to change the brake pipes? is it hard and also would i b better of changing the whole lot?
any help is greatly appreciated.
Posted: Tue Jun 12, 2012 11:47 am |
You'll need a flaring kit, pipe cutter, brake pipe unions, pipe and fluid. It might work out less hassle to get a garage to do it rather than buying the tools.
For the pipe, fluid and unions go to your local motor factors, not Halfords.
Posted: Tue Jun 12, 2012 12:01 pm |
thanks dude, yeah got all the tools i need of a friend of mine and have a we bit of xperience around the 206 but never brake pipes. its more the technique i need lol
and your right f*&^ halfords.
You can post new topics in this forum You can reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
