Latest: S2cgm
Overall: 17178
Online Now [124]:
Visitors: 123
Today: 69348
Total: 136856419
Forums › The Car › 206 Problems › I've lost the horn
I've lost the horn
Ali_H
PostPosted: Wed Jun 13, 2012 2:32 pm Up
Car went in for MOT today and the only thing it failed on was the horn not working; weird as I checked it before the MOT.
So I took the fuse out and put it back in again and it worked... until I got it to the test centre and it wouldn't work again :@
Changed the fuse and it still doesn't work properly but will sometimes. The guy down there said the horn might be faulty but if that was the case surely it'd never work? What's the best way to get the horn off to check as I really dont want to be taking off the whole bumper to do it.
kurtis wrote:
broadblaster
PostPosted: Wed Jun 13, 2012 2:35 pm Up
can you get to the wireing to pull the plug off the horn ??? if you can just fit a new one in a diffrent place mate saves takeing it all off.
on a back road playing
PostPosted: Wed Jun 13, 2012 2:41 pm Up
Maybe just not feeling very horny down there matey lol
Just get another from scrappy for fiver that's all I did
Ali_H
PostPosted: Wed Jun 13, 2012 2:43 pm Up
Na i've tried, maybe I just got short arms Laughing
kurtis wrote:
broadblaster
PostPosted: Wed Jun 13, 2012 2:49 pm Up
bummer looks like bummer off job then.
PostPosted: Wed Jun 13, 2012 3:05 pm Up
Is this not to do more with the contact point behind the airbag?
PostPosted: Wed Jun 13, 2012 3:22 pm Up
Same thing happened to me. I thought it was the Steering wheel fault, but it was the horn. It would beep now and again, but eventually died. It is a bumper off job! When you change it, turn the trumpet towards the car, crap place for the horn to be as it takes in water. Also check the terminals for corrosion.
PostPosted: Wed Jun 13, 2012 4:59 pm Up
Probably a corroded connection on the horn itself.
PostPosted: Thu Jun 14, 2012 12:33 am Up
Check the relays in the engine fusebox.
Ali_H
PostPosted: Thu Jun 14, 2012 1:26 pm Up
You can hear the relays clicking in the fusebox ok. I suspect it's the horn or connections, stupid place for a horn anyways.
kurtis wrote:
PostPosted: Thu Jun 14, 2012 1:31 pm Up
It'll be the connector that's knackered. Usual poor placement of things in the car, like having the ECU under a vent which water gets in.
PostPosted: Thu Jun 14, 2012 1:34 pm Up
Its such a known problem that Peugeot sell a horn connector repair kit Laughing
