Latest: lio94
Overall: 17181
Online Now [266]:
Visitors: 265
Today: 77032
Total: 141944069
Forums › The Car › 206 Problems › 2.0 Hdi No Start
2.0 Hdi No Start
mask0017
PostPosted: Sat Jun 16, 2012 12:15 pm Up
ok cars been running fine went out 2day and get Engine Immobliser Fault.
Plugged in planet and bsi test comes back with Can't communicate with Engine ECU
Any Ideas.
Tried Bsi Reset still no go. Got ecu dissconnected and Battery on charge
Will try again 2moz.
Was thinking it may have a wire shafted somewhere
Evil or Very Mad
260 LX 2.0 HDI
PostPosted: Sat Jun 16, 2012 12:17 pm Up
Try other key
mask0017
PostPosted: Sat Jun 16, 2012 12:33 pm Up
yip have tried another key same thing
may be the pick up ring i suppose
260 LX 2.0 HDI
PostPosted: Sat Jun 16, 2012 1:06 pm Up
test by ecu > EDC15 > parameters > immobiliser
test by ecu > BSI > parameters > immobiliser
match?
mask0017
PostPosted: Sat Jun 16, 2012 1:37 pm Up
ok will try that 2moz as towed car to my shed and been drinking now
THx
260 LX 2.0 HDI
mask0017
PostPosted: Sun Jun 17, 2012 5:35 am Up
ok plugged in planet tried global test NO REPLY FOR ENGINE ECU
went to test by ecu > Bsi and get pernanemt fault no commmunication with engine ecu
260 LX 2.0 HDI
troy
PostPosted: Sun Jun 17, 2012 10:18 am Up
have you checked fuses? and main relay ?
2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd
mask0017
PostPosted: Sun Jun 17, 2012 12:31 pm Up
yip tried fuses not looked at relay
F15 30amp fuse in engine fuse box
fuse is ok but no power reading at that fuse
260 LX 2.0 HDI
