Latest: S2cgm
Overall: 17178
Online Now [1041]:
Visitors: 1040
Today: 64534
Total: 137131500
Forums › The Car › 206 Problems › gti keeps stopping when cold ok after 5 mins
kustomkriss
PostPosted: Sun Jun 10, 2012 2:01 pm Up
my 99 gti keeps stopping and ticks over rough when cold and smells like its over fueling when i have the window down but is ok after about 5 mins
modern petrol cars are abit alien to me as ive run diesels for about 12 years so forgive my stupiditity but last petrol car had a carb and a choke cable Embarassed
206 gti 99 42,000 miles
Deckchair5
PostPosted: Mon Jun 11, 2012 12:20 am Up
Use your experience to relate to modern cars. Many things are the same. Do the basics, make sure plugs and air filter are in good condition. Rather than a coil and separate plug leads, it's all in one coil pack
What made you decide to use more choke on the older cars? The engine temperature
How do modern cars determine engine temperature? The ETS
What made you decide to put the choke back in again? The engine temperature and the exhaust sound rich or lean?
What checks out the exhaust for the correct mixture? The lambda sensor
kustomkriss
PostPosted: Mon Jun 11, 2012 3:42 am Up
whats an ets
when started it seems as though its gasing its self up like when you left choke out
car had been sat for two years when i bought it only taken for mot then parked back up
MrMorris
PostPosted: Mon Jun 11, 2012 7:01 am Up
my car does similar thing. chugs and bounces around when cold, but once warmed up (2-3mins) its absolutely fine. bare in mind only only did it on cold days (winter mainly, hasnt done it since march this year)
what about spark plugs? or are they part of the coil pack on these cars?
chief93
PostPosted: Mon Jun 11, 2012 12:34 pm Up
your ICV (Idle control vale) may need a clean? if its ticking over all lumpy and uneven
1.6 Xsi - Work in Progress!
"If it has wheels or a skirt, it's gonna give you problems."
MrMorris
PostPosted: Tue Jun 19, 2012 4:27 pm Up
change the coolant temp sensor. worked perfect. and makes 100% sense to be the fault causing your problem.
fixed my problem, which was your problem.
