Latest: tebas93089
Overall: 17179
Online Now [116]:
Visitors: 115
Today: 29920
Total: 138083105
Forums › The Car › 206 Problems › Non Electric to Electric Mirrors
Mephisto
PostPosted: Fri Jun 22, 2012 11:23 am Up
Hi,
I know its be covered before but i am having problems..
I have looked under my original window switch and it appears that i have the connection for electric mirrors, I took my old mirrors of and they had a brown plug, with 4 wires i think, the new electrics have a white plug with 9 wires or so.
I bought a whole door wiring harness, but when i got it home i noticed that the connection is different.
MIne has what looks like just a square plug, as opposed to this
Any body got any ideas of how i can splice this..
to my original door harness, or am i onto plums??
This is the original plug...
Cheers if anyone can help
Blah Blah Blah
Walton450
PostPosted: Fri Jun 22, 2012 1:41 pm Up
what year of car is yours and what year of car did you take the loom off?
I\'m Steve got a 2003 verve.
iainlovatt
PostPosted: Fri Jun 22, 2012 1:53 pm Up
well here are you options
plan a)Cut both connectors off and hardwire
plan b) buy some new mirrors Smile
(My Garage)
spike_202
PostPosted: Fri Jun 22, 2012 1:56 pm Up
On the splice subject you would have to cut into the wire somewhere near to were your holding it and just run a wire off a solderd joint. then join it up to were ever you need to go with a long wire then use some loom tape/convex tubing to cover it up.
**spike's project**
TEAM:+200bhp
Mephisto
PostPosted: Fri Jun 22, 2012 5:02 pm Up
What i really need to know is what the what wires do what, im not sure would i run a wire from the electric mirror to power it, but what wires would control it..I think i might just scrap the idea of having working mirrors and just have the switch fro show...ballderdash!
Blah Blah Blah
iainlovatt
PostPosted: Sat Jun 23, 2012 3:14 am Up
No you cant give up lol! Its worth it in the end!! Give me a better picture of the end so that i can clearly see the wires and i will tell you!! Probably easier if you pm me as got lots of work to do today and cant regularly check!
(My Garage)
