Online Now [209]:
Visitors: 208
Today: 5118
Total: 142995246
Forums › The Car › 206 Problems › electric mirror switch
PUGPAUL
PostPosted: Tue Jun 19, 2012 6:07 am Up
...does the electric mirror switch 'knob' pop up if you lightly pull it upward by default? ...or is mine broken? When pushed back down into the switch socket it functions perfectly well.
cheers!
i.e. no point in getting another, if they all do this by design.
Peugeot 206 HDi (1.4cc) 'eco' - 2005
Lecktorious
PostPosted: Tue Jun 19, 2012 6:11 am Up
Trade Rating: +59
Sounds like it's come loose. Would just glue it back in place.
'98 Nile Blue 306 GTi 6
PUGPAUL
PostPosted: Tue Jun 19, 2012 6:26 am Up
...it doesn't detach from the switch housing: the 'knob' is attached to a 'stem' that goes through the top of the switch housing; something at the other end of the stem (the bottom end) is preventing it from pulling free of the switch housing, perhaps it widens out and is too big to come through the top of the housing? Therefore, the only way to get glue on there is to completely dismantle the entire switch assembly?
any ideas?
andyleep
PostPosted: Wed Jun 20, 2012 12:33 am Up
Yours is broken. But if it works ok............
PUGPAUL
PostPosted: Fri Jun 22, 2012 9:29 am Up
thanks Surprised
Lecktorious
PostPosted: Fri Jun 22, 2012 4:15 pm Up
Trade Rating: +59
If it's physically broken off, some glue will reattach it. If it's just loose and not affecting the functionality of the switch I'd just leave it.
