Latest: tbafonso
Overall: 17130
Online Now [528]:
Visitors: 527
Today: 21298
Total: 103607135
Forums › The Car › 206 Talk › mpg on throttle bodies
usher
PostPosted: Thu Feb 16, 2012 6:32 am Up
as title what mpg do people with throttle bodies get
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
nakednakeddave
PostPosted: Thu Feb 16, 2012 8:23 am Up
why would you want throttle bodies if your worrying about mpg.....?
fat exhaust, dodgy rusty bonnet, stickers and steels....
KRU KREW
PostPosted: Thu Feb 16, 2012 9:22 am Up
I\'m with stupid!
Big_Rich180
PostPosted: Thu Feb 16, 2012 9:28 am Up
I\'m with stupid!
What She Said
usher
PostPosted: Thu Feb 16, 2012 10:45 am Up
reason im asking one is to find out and second its my daily drive so if its going to be silly mpg i might not be able to do it
im covering all areas before forking out over 2k on it
project thread WIP
garage
FAQ
206 gti firedance
Andrew
PostPosted: Thu Feb 16, 2012 10:51 am Up
Not the same engine but its similar- forum.205gtidrivers.co...5837&st=20
My 206 thread
www.detailedbyandrew.com
copey
PostPosted: Thu Feb 16, 2012 11:04 am Up
personally i think spending 2k on something to make what essentially is not a particulary amazing car (not yours just them in general) seems like quite a waste better off putting the 2k towards something faster in the first place
02 2.0 hdi d turbo
PostPosted: Thu Feb 16, 2012 11:06 am Up
but then you have something that is the same as everyone elses and not different Laughing
PostPosted: Thu Feb 16, 2012 11:27 am Up
People say the same when i say how much ive spent on mine (high 5's rising fast)
My car will win shows, no one has a car the same, and lets face it would you get as many looks in a 207 gti as you do in my 1.4 turbo Laughing
Icetto
PostPosted: Thu Feb 16, 2012 12:30 pm Up
Wise words there Addaz
usher
PostPosted: Thu Feb 16, 2012 12:52 pm Up
totally agree with addaz ive hit the 5k mark and wouldnt swap it for a faster car as this is my car how i want it
basically i wanna know if i can afford to run it on tbs
project thread WIP
garage
FAQ
206 gti firedance
usher
PostPosted: Thu Feb 16, 2012 12:56 pm Up
Andrewxps wrote:
Not the same engine but its similar- forum.205gtidrivers.co...&st=20
thanks was a good read
project thread WIP
garage
FAQ
206 gti firedance
Lecktorious
PostPosted: Thu Feb 16, 2012 1:24 pm Up
Trade Rating: +59
If you're worrying about running costs just now, you probably can't afford them.
'98 Nile Blue 306 GTi 6
PostPosted: Thu Feb 16, 2012 1:45 pm Up
unless you do silly mileage per year otherwise the difference is minimum.
let say you do 8K mile per year.
the difference between 30mpg and 25 mpg is only is only 53 gallon, which is roughly 320 quid.
that means less than 1 quid per day.
PostPosted: Fri Feb 17, 2012 2:57 am Up
£2k on a ssheddy 206 isn't worth it. If its a decent example then it is. Your experience of an 206 HDI doesn't give the same impression that a decent petrol engine would.
There are other factors to think about with mpg with cam choice etc. If its set up properly it won't be significantly thirstier.
