Latest: lio94
Overall: 17181
Online Now [174]:
Visitors: 173
Today: 142029
Total: 140779974
Forums › The Car › 206 Problems › Rear Axle
Rear Axle
GTSX
PostPosted: Fri Jun 22, 2012 12:17 pm Up
I had a problem with the rear axle and trailing arm bearings so I took it off the car to strip it down.
I got the arms off and found the machined axle end was badly worn but with a good friend we found new axle ends and so removed the offending item and waited for the new parts to arrive. Here now, today.
I forgot to check something before we stipped the axle. So as I'd like to lower the car by 40mm. can anyone tell me with the axle on a bench laying on the 4 mounting points, what height should the centre of the stub axle on the trailing arm should be from the bench?
Also where can I get some new uprated axle mounting bushes from for putting it back on the car?
GTSX
PostPosted: Sun Jul 08, 2012 6:06 am Up
Well a few views but no answer!
Where can I get uprated raer axle mounting bushes?
Squeaker
PostPosted: Sun Jul 08, 2012 7:52 am Up
Have you thought about
